I have a 1959 10 hp evinrude sportwin 10018, from what I gather it's also referred to as a QD20 or its very very similar to a QD20 not entirely sure. Got it for free because there was essentially no lower unit so I have to rebuild one. Found what I feel like is a great tutorial on how to rebuild a lower unit for my model. Now the lower unit has been closed up and filled with oil. Once it's back onto the motor there is no forward gear. If I put the motor into forward there is little to no movement in the prop, id say no movement really. But in neutral the prop goes full reverse. Same thing once it's put into reverse position it continues on in full reverse. It's as if inside the gear case the clutch dog isn't engaging the prop shaft in forward position. Also when the motor is off and in forward if I attempt to spin the prop by hand it spins freely with no resistance. Just at my wits end so here I am.I have seen on some forums people saying to "adjust the shift linkage" but I cannot find anything anywhere to explain how to do that exactly, also saw something about how if the clutch dog is too worn out that could be a problem. I wasn't able to find a forum where someone had my exact problem though. If anyone here has some ideas throw em at me. I could use some helpful advice. Thanks for your time.
