Hey guys, I searched for my issue here but honestly couldn't find it....this is a pretty big and active board. My question is: When I am replacing the lube in the lower unit for my 2015 4 stroke 20hp Mercury can I "top off" the lube via the top oil level hole?? I ask because my fill hole is literally pointing straight toward the ground which means new oil comes pouring out when I remove my hand pump line and ATTEMPT to replace the plug while the oil is coming out...why they positioned this fill hole like this boggles my mind.....unless of course I'm an idiot and missing something obvious...however, referred to my owner's manual and it appears filling from the bottom Fill hole is correct....please help...I don't want to be running on low lube
