RosieB12
Hi folks ... I'm a newbie, so bear with me. (b.t.w. - I tried getting registered on Marinette Boat Forum, but can't seem to stay logged in.)
Now ... my new (old 1988) Marinette 32 flybridge is in the water. Chrysler LM318 engines ran well after launch for about 30 minutes and I got her into the slip. I replaced two gunky fuel filters (filled them, but forgot to otherwise prime engine). Port engine started fine & runs well. Starboard engine began to turn over, but then I got a very LOUD SCREECHING sound and the engine was not cranking. Screeching stopped only when I turned off the ignition. I believe this is a starter motor breakdown? Any other thoughts? Is replacement as easy as just (1) disconnecting battery leads, (2) removing the two bolts, and (3) sliding out and replacing the starter?
Also... the port engine has an ID plate in place with ID numbers indicating LEFT prop rotation, and a symbol on top of the block that seems to show CW rotation. My starboard (troubled) engine has no ID plate anywhere, but the symbol on top seems also to show CW rotation. Is it possible (likely) that both engines have CW rotation? I know a replacement starter will need to match THAT rotation, right? Thanks... BILL
