I have a 2019 Mercury 115 4S EFI on a Bayliner VR4. Last season the lift tilt started acting up. It worked fine up and down UNTIL I brought the engine all the way down. Then it would not lift (left motor would not make any noise when I pressed up but would whine when pressing down). ( both at the throttle handle and the engine). If I released the hydraulics and lifted the engine 6-8 inches, retighten it, the lift/ tilt worked fine up and down unless I went all the way down and the the up stopped working. Dealer replaced the lift motor under warranty and it worked fine for the rest of the season. Stored inside for the winter and upon getting it ready to launch and the problem recurred. Brought it back to the dealer and , wouldn’t you know , we could not replicate the problem. Worked fine. Put it in the water and the problem happened again. I took off the cowling and reversed the motor wires ( blue to green and green to blue) pushed the down button and the motor lifted. I reconnected the blue to blu and green to green and the lift/ tilt works fine. I did not bring it all the way down to see if the problem persists as rain was coming momentarily.
The mechanic at the dealer is baffled ( as am I) and says they have never heard of this problem and it defies logic.
Any ideas?
Any ideas?
