@ daselbee, No i still haven’t received it, I been going thru the wires soldering connections and stuff, the other day I re did the ground from the power pack, soldered a new connector, soldered the black and yellows too, the only problem I found was that the back and yellow for the starboard side had broken at the connector itself so the motor would not shut off that bank, fixed it and now it shuts off, I ordered the new t/b and new p/p but not installed them, the motor has been starting quickly with no issues the ground at the p/p I want to say that was bad, but I did had continuity to ground there, but you could tell that the wire was damaged so I fixed… so I still don’t know, I’m going to let the motor sit for a 4 or 5 days and see what it does...the fact that the motor runs does not help my confidence, but what else can I do???
