You'll need to get carb kits to have all the parts you need. I've attached a blown up diagram of your carbs. You'll need to remove pulugs #4 and #5 and clean out the passage behind those plugs. The kit has the replacement plugs. Be sure to remove and thoroughly clean out the jets #27 and #35. Be sure to adjust the float levels to the recommended height. Soaking the carbs overnight in a gallon bucket of carb cleaner with a basket strainer in it that you can purchase at most automotive parts stores is a great start. Then using a compressor to force air through all passages includin the jets is a must. If you don't have access to an air compressor, spraying aerosol carb cleaner is the next best thing. Hold the jets up to a light and you should see a perfectly round hole. If not, you're not done cleaning it out. Mark the carbs when you take them off. They're all different.
