This is a new thread, former postings under "Johnson 1991 28 SPL Problem"
Regarding: Johnson 28 SPL 28SPLE28ESLCEA
with Electric Start
with Console Throttle / Warm Up Lever / Ignition and Choke
2 Cylinder, 2 Cycle
Use: Currently on 1971 Harris Flote Bote
Concern: Cannot get the engine to run consistently at High Speed and Low Speed at the same time.
Fuel: Non-Ethanol
50:1 2 cycle Oil Mixture
Tank: Clean, No Debris
No Vacuum Lock
Tank to Engine
Fuel Line: Good Condition, Line and Primer Bulb
Coupling to Fuel Pump
Fuel Line: New Fuel Line Added
In-Line Fuel Filter Added
Fuel Pump: New Fuel Pump Installed
Primer
Solenoid: Refurbished with Kit
New Top Plate
New Lever with Schrader Valve
Tested Solenoid, Activates when current applied
Not Tested, Pressure Seal
Carburetor: Refurbished with Kit
New Top Plate Gasket
New Drain Plug Gasket
Main Jet Cleaned, No Obstruction
New Float, Needle, and Seat (Note; Float is installed in correct direction, not upside down)
New Emulsion Tube Gasket
New Welch Plugs
Carburetor Cleaning:
Disassembled, removed Welch Plugs
Flushed with generous amount of Sea Foam
Top and Lower Caps Ultrasonically cleaned
Flushed (again) with Carburetor Choke Cleaner
Note; Upon disassembly, no debris found in Carburetor however Emulsion Tube openings appeared to be slightly gummed up.
Spark Plugs: New QL77JC4
Gapped to 0.030"
Verified to Spark
Lower Housing: Fresh Gear Oil
Water Pump: Okay, good Water Flow
Limitations: No Service Manual
Not Checked: Timing
Cylinder Compression (required value unknown)
Fuel Pump Compression (should be 2 lbs / sq in?)
Ignition Points
Current Condition: Runs at High Speed briefly, then dies.
I cannot seem to get this engine to perform adequately at both Low and High Speed.
Most recently, I had this running well at low to mid-range throttle but then the engine would die when I attempted to run at high speed.
I took the carburetor back off and found that, while top position of Float was level as recommended.
The Float drop was at 0.8", so my assumption was that I had been starving the engine of fuel.
Now, with the Float drop at 1.3", the engine will only run briefly at high speed. Will not start without starting fluid.
It doesn't make any sense.
Carburetor Follower is set to dead center of Cam notches at low speed idle.
No High Speed Idle adjustment on this carb.
Low Speed Idle adjustment set to 1 1/2 turns counter-clockwise from close.
When the engine stops and I remove the Carburetor Plug, there is fuel in the carb, but when I remove the Spark Plugs they are dry.
There is no reason to suspect bad spark, timing, or compression...though those can't be ruled out since I haven't the equipment to test them. In any case, I don't know the what the proper values are.
I have followed all of the logical steps for tuning this engine, but success eludes me.
This has to be the something I'm doing wrong or overlooking with the Carburetor.
It has gone from fuel starvation to flooding to starvation again.
Any help / fresh ideas would be appreciated.
Photos upon request.
with Electric Start
2 Cylinder, 2 Cycle
Fuel: Non-Ethanol
No Vacuum Lock
Tank to Engine
Primer
New Top Plate
New Welch Plugs
Gapped to 0.030"
Verified to Spark
Not Checked: Timing
Ignition Points
