Hi all,
I have a 1994 Johnson 130hp V4, We have an issue with the engine not firing on all 4 cylinders when cold and under load. Once the engine revs increase and you start to plane the 4t h cylinder will slowly kick in then your away and won’t fault for the rest of the day. It only does this when it’s been parked up for more than a couple of days.
I hadn’t replaced the plugs since we owned it so thought I would start there, I noticed one of the plugs was fouled and had a droplet of water between the gap. I installed the new plugs then tested it straight away and didn’t miss a beat.
Now am I looking at a potential head gasket leak or do these engines have liners that can crack,leak?.
My dad took it to a shop last month to get them to check it out and they replaced plugs thermostat and compression tested it.
compressions were 115,110,110,115 PSI.
We have a friend who has just installed a new Suzuki on his boat which runs like a clock, just wondering is it time to unbolt the Johnson it and watch it sink to the bottom and go new. Haha
Any help appreciated.
