vincentmb615
Good day all, picked up a 94 1930 with the Merc 4.3 I bought it with a known bogging issue and I'm trying to hunt it down, it sat for a week and I went to start it on muffs and it was taking forever, so I pulled the fuel line off and there wasn't any fuel in it so I ran power to the fuel pump and got fuel into the carb and it fired right up, but backfired a little and died, is the anti syphon valve supposed to keep fuel in the line or does it allow it to roll back into the tank? I tried to remove it and it snapped off it was corroded so I had to pull the pickup tube out as well, I have a new anti syphon the pickup is on order, isn't it supposed to have a filter on the end of it? And is there a certain length it should be? I could only find the size I needed in 24 inch so It will have to be cut down . Do you think replacing all this will solve the bogging? Its so intermittent it's hard to trace, plugs cap and rotor are new as well as fuel pump and seperator vent is not clogged
