1987 165 mercruiser, Aplha 1, Gen 1
Couple weeks ago I took a hard hit on the prop/skeg. I was powering up from a crawl, hit a rock, banged up the prop, broke off most of the skeg.
when it hit, it seemed to disengage from gear, but after powering back down, it re-engaged fine. There was no visible damage to the gear case, so I just put on my spare prop., and everything seemed ok.
I used the boat for the next two days, everything worked ok. Then the shifting started acting up.
It seemd like it became way out of adjustment. First it seemed to get stuck in reverse, trouble getting it to shift into forward, then finally couldn't shift into forward at all. It would shift into reverse, but difficult to get out of reverse.
Tried pulling off the lower cable from the shifting bracket and shifting manually (while docked), but had the same symptoms.
Finally had to pull the boat out.
I was convinced that the lower unit was damaged, so I bought a used unit and installed it.
Out of the water, while running, it seemed to shift ok. Tonight I put it in the water for a test run, and found I had not solved it.
Initially it shifted ok, but then the same symptoms returned.
The shifting became way out of wack, and ultimately would struggle to go into forward, and would struggle to get out of reverse.
When installing the lower unit, I did not see any damage to the upper to lower shifter connection, and I'm certain I had it properly aligned when I installed it.
Could I have pulled something loose in the shifting system (cable connection, some other component?) or is there some other common failure that I am overlooking?
