If you want static only, your choice is to mark your balancer, turn the engine over in the standard direction...., stop the crank at the degree desired...., then with ignition ON, rotate the distributor in a CCW direction until you get a spark.
With the crankshaft pump installed, that is correct!Many thanks for the reply, but the qestion is how do I turn the engine over? There is nothing to get a socket or spanner on
