Welcome aboard !
You will have a pm in a few minutes after i post this.
Do not worry about the words when you see my pm you will understand better.
You have 3 sep. drives. Plus a tilt clutch housing.
Looking at the drive from behind on the very top you will see a large quarter size screw in the intermediate drive, the one coming thru the transom, unscrew it. Look under the drive on the intermediate, you will see the drain it is right close by the steering gear. Pull the screw and let the intermediate drain.
Looking at the very top of the drive itself is the dipstick- pull it. Looking at the upper drive right starboard side is the drain plug pull it, it will have a magnet on it.
Looking below on the lower is the vent plug pull it, and the the very oiwerst plug is the drain, pull it, now you have the 3 drives draing with the drive fully down.
Ok will take a while to drain, looking at the left side port, is the tilt clutch housing, i will post a write up concerning that one after i'm done i wrote a while back.
Time to fill the drive, i start at the bottom most plug, screw in your pump, pump slow till you see gear oil " I buy mine in the gallon size from wal-mart you need 80-90 weight anything with a picture of a boat on it " come out the vent hole above it.
Install the vent plug then unscrew your pump and install the fill plug the one with the magnet on it use a fresh plastic washer i get them from home cheapo 1 dollar for 10, or any marine store will have them, more money.
Now i unscrew the vent again on the lower and let the air out for about a half hour while i fill the upper drive from the bottom, be careful you don' really want it gushing out the top dipstick tube. I will post the amount that goes into each drive latter when i look it up.
upper full put the dipstick in unscrew the pump from the fill install the fill plug with the magnet plug fresh washer and then pull the dipstick and let sit for a half hour.
Install the drain screw in the intermediate, fresh washer, the squeeze in from the top real slow the intermediate fill till full.
By this time you can stick a wire into the vent on the lower if still full then you can close up the lower same with the dipstick, if still full see the upper and the lower might burp sir then you would have to top them off.
You done with the intermediate close it up.
7 oz for the intermediate
26.7 oz lower
16.6 oz upper
