For a battery bank in need of charge, you may see 14.8v for a duration. Your alternator should cut the charge rate back fairly shortly.14.6 on the right motor, 14.9-15.2 on the left motor, is this way to high or acceptable ?
Again, depending on which ignition coil.Do you have electronic ignition conversions? Many require you to remove the ballast and run the coil at 12v.
Dan
