Thank you for your reply.
This has only just happend, I'm going to the tender later, I will jump the green & black wires on the red diagnostic plug, then reset the codes by pulling the cut out switch 5 times within 10 seconds.
Also, I will replace the battery terminal lugs as they are missing with the positive cable wedged inbetween the battery terminal and ring, maybe its a case of not enough amps to support the higher rpm.
The PGM-F1 light and long intermittant buzzer came on a few minutes prior, I stopped the engine and restarted its no longer coming on.
The green light stays on as normal, all 3 red lights come on and go off after starting.
I use the tender almost daily, over a week ago the coolant light came on, but that has not come back on and there is water coming out of the engine cooling outlet.
The tacho is not working so its difficult to gauge the max rpm, but it has been feeling a slow for the last couple of months, taking longer to get up on a plane.
A bought the boat and tender in Vietnam during covid, its been sitting there on the hard for a couple of years, the skipper who brought it back to Thailand with me said he did a full service on the tender engine, we arrived here two months ago and I've been using it to go to and from the boat since.
I replaced the throttle & gear shift cables yesterday, am awaiting delivery of the c-cap for the throttle rod end hence the improvised throttle control.
Regards
Arran.
