I have twin Honda 150s that are 2015 motors with 900 hours. The Port engine runs perfectly. The starboard engine runs great except that when both engines are set to around 3500 rpm the starboard engine will surge up and down from 3200 - 4000 rpm. When I shutdown the port engine and run just on the starboard engine, it does not surge. If I drop the port engine down to 2500 rpm and run the starboard engine at 3200-4000 the starboard engine does not surge. When rev up starboard engine out of gear it does not surge. I have tried
1. Different trim angles - no change
2. Adjusted the steering angle of the two engines - no change
3. Removed the transom transducer located on the starboard side - no change
4. temporarily disengaged the Air Intake Bypass so it is always working on the high speed runner - no change
5. I have new/clean filters
6. I have good fuel and fuel lines
At any other rpm the engine runs flawlessly. I welcome any thoughts.
