I have a 2004 BF 135A. Engine alarm sounded. Mehanic said code indicated a defective MAP sensor which was replaced. Alarm sounded again after running less than 10 minutes. Code indicated bad LAF Sensor which was replaced. Alarm sounded again during short sea trial. Mechanic counsulted Honda (again) replaced the EMC controll unit. Alarm still sounds. Mechanic checked and clead all pins checked continuity, grounds etc. Hooked up portable ignition box to eliminate harness issues. I had the mechanic disconect the alarm. Engine was difficult to start but ran well for 2 hours. Now it runs rough and can only run at idle or it will stall.
Do I cut my losses at this point?
