perryrlund
I posted a thread on April 7 regarding my 2014 Honda 9.9 overheating. Thanks to Jgmo, ChrisHading, william01 for your answers. I took it apart and there was no issue with the waterpum impeller or the thermostat. I ordered a new water pump kit, thermostat plugs, oil, lower unit lube and am doing a whole service routine. I've done everything but naturally, the water pump kit is on backorder. I ordered everything through my Honda dealer and wanted to make sure I have all original Honda parts going back in.
As I did everything I had to do except the water pump, I had it sitting on the bench so I decided to do a dry run with the old water pump assembly for a practice run so I should have no problems installing the new one. I put the impeller in the water pump liner and slid the water pump liner down the shaft onto the spline. At that point I noticed the water pump liner was not fitting tight within the impeller housing. I never changed a water pump on an outboard before but this did not seem right. I inspected the water pump liner and it has the two bosses on top that I assume are suppose to engage inside the impeller housing to lock it in place and then the impeller spins inside the water pump liner. One of the bosses was sticking up at a 90 degree angle and the other one was bent flat. I'm assuming this is not correct, that they are both suppose to be at 90 degree angles. On the old water pump liner I bent the flat one upright and it now fits tight in the impeller housing.
As the water pump assembly is on back order, I don't have a water pump liner in hand to compare it to but can someone answer if both of these bosses are suppose to be at 90 degrees so it sits tight in the impeller housing and then when the shaft turns, only the impeller turns and the water pump liner stays stationary inside the impeller housing and does not turn.
If this is so, any opinion as why this happened? My only though would be somehow the spline got dislodged and caused the issue but the water pump liner and everything was in perfect condition. Nothing at all was damaged, it looked as new as the day it left the factory. There was no event that occurred, the water pump was working fine this spring and then it just stopped and then when I did some jocking with it I could get it to pee a little bit and at times there was a full stream and then it would stop. The only thing I can think of that makes sense is somehow the spline came loose and when this occurred the water pump liner was spinning on the shaft with the impeller and was not doing much of any thing but peeing a little water at times. The channel in the impeller for the spline is in perfect condition as well, it's not tore up in any way.
This one has me scratching my head and I would appreciate any input from the experts. I'm pretty good with mechanics but this is my first water pump experience and it's been anything but by the book. Thanks for any help you can give.
