Hi all
New to the site,
I got a used 2008, mounted it and ran it. Heat alarm goes off at high throttle. Call mechanic and he says new impeller and housing so got that done. Test run and no change. Then did internet research and change 4 temp sensors (1 was pretty caked), checked t-stat with hot water (all good). Test again and no change. Opened the side and check the high pressure relief and ran a garden hose in the T-stat opening with the lower unit off to back flush. Test run and same thing. Anything else?? I did not change t-stat or relief valve assy. Should I? My next move would be taking off the lower unit and check the connect of the water tube and up, remove all hoses and check for debris stuck. Forgot to mention my piss indicator is strong running. Shops are a month+ out for appt.
Can someone explain how the pressure relief travels? I have an idea of how it works. The reason I ask is the picture on Boats.net has the part spring down and pop upward but the actual way it is placed is with the spring up and pops downward. With spring pretty firm, I can not figure that it would create enough water pressure to open the relief valve.
Thanks in advance
Thanh
New to the site,
Thanks in advance
Thanh
