Duck Dingy
Here goes.... I recently purchased a (from what I can tell) is a 1999 or 98 M40C. I've taken it out twice do far. Sunday afternoon it was running just fine and then completely shut off. No stutter, nothing... It just died. After removing the engine cover, I noticed a leaking fuel hose, couldn't fix it on the water. Got towed back (embarrassing). So today I installed all new fuel lines, tore apart, cleaned, and reassembled the carb and installed 2 new spark plugs as well. After if was all said and done, she still won't fire....even using ether. I unplugged the kill switch and still nothing. I unscrewed both plugs and grounded the to the case and they're both firing strong. The carb is getting plenty of fuel, obvious to me after I cracked open the drain screw in the bottom of the bowl. I'm stumped. Hopefully it's something easy and you can save me tons of money and time. Duck season is less than a month away and I can't wait. Thanks for your help.
