Swampbilly
Hey guys,.
I'm running a 1984 Johnson 150 on my V-20. Had the carbs re-built last May. Afterwards, she ran great and used it all summer, every weekend. I noticed however, that after running for about an hour and shutting the motor off, that it gradually became harder to start after it sat for a short period of time-(30min.). You could smell gas. Had to choke it eventually to get it started, and then she was a little sluggish initially when throttling up, and then it would clear up and run fine untill you shut it off again and it sat for a short period.
Now this year, you can run about 4-6 miles, and the motor will bog down and shut off,..you can smell gas, and it appears to be flooded up...Won't start untill it sits for a few hours. When I disconnect the fuel line to the motor,..there's significant pressure , and gas shoots out from the connector on the motor. I replaced the fuel line (bulb), as one time it was collapsed which made me think the pick-up was clogged in the tank...The 90deg. elbow that goes into the tank (for pick-up) is WELDED ON, so it cannot be removed to check the pick -up, (ain't that a crock?). I checked to see if the check-ball (anti-siphon) was sticking in the tank possibly from Ethanol contamination..there was no checkball. I'm kinda' stumped here. Thots?....
