I mistakenly removed the cover plate (4 screws in each corner) from the top of the upper gear case on my 2005 Volvo Penta DPX sterndrive, exposing a large roller bearing. (I had also removed the cap that covers this plate and the area where the shift cable attaches.) When I did this oil starting running out of a "weep" hole about half way down the side of the unit. It did not appear that I damaged a gasket or seal that might be under that cover plate but I'm not sure. I quickly replaced that plate but oil continued to run out for a few minutes. I lost probably a total of 2-3 oz of oil.
I'm a rank amateur in this area. Does this top plate have to be replaced with a specific torque? Should a seal be replaced? How to replace the lube (oil) that was lost? Is this a job that I should immediately refer to a qualified technician?
Thanks. vpamateur
Thanks. vpamateur
