I did install a new impeller, I did reconnect the shift rod, the one to the brass connector with the two screws.Shift rod connector probably is not connected. Remove lower unit and looksee.
There is a gasket under the top starter bearing plate.
Should have carb kits here at this website.
I do have a video of the leak but don't know how to bring it hereI did install a new impeller, I did reconnect the shift rod, the one to the brass connector with the two screws.
Wow it looks like I'm @2ft short.It calls for starter rope cut to 65-1/4"
