" 83 Evinrude 50 HP
Here ar
" 83 Evinrude 50 HP
Here are the symptoms . . . all this happens on the water, by the way.
bulb goes soft after running
in line fuel filter from tank to engine goes empty
dies at idle (after a while)
dies in gear (low rpm)
runs rough
It does go to 4900 RPM's and runs fairly well the rest of the time. A little rough at WOT, but not bad.
What I have done -
-rebuilt carbs
-replaced fuel hose (tank to engine)
-replaced tie wraps with metal clamps
-have added Sea Foam to last tank of gas (still have it in tank) - had 1/2 full tank I added it to, then later added more gas and oil
-cleaned gas tank and filter on pick up tube
-cleaned fuel pump filter
-re-adjusted linkage
-replaced throttle cable
I am going to rebuild the fuel pump, but am wondering if I can just pull it apart and clean it, or are there parts that I need to replace.
So, does it sound like the fuel pump and, if so, clean or rebuild?
Thanks,
Jason "
Here ar
" 83 Evinrude 50 HP
runs rough
What I have done -
-rebuilt carbs
Thanks,
Jason "
