tiller man
I have built and rebuilt the fuel pump on my 4 hp Johnson outboard. I have followed all directions but it will not pass the toot test. Inlet and outlet valves work just fine. What do I try next?
Ron
Ron
and the final testing ( as Racerone has already said):NOTE-- THESE ARE A PITA TO GET RIGHT THE FIRST TIME & MAYBE EVEN THE SECOND TIME AROUND, SO IF OR WHEN YOU DECIDE TO GO INSIDE YOUR PUMP BE VERY OBSERVANT.
Fuel Pump Test
You SHOULD be able to blow thru the pump by blowing into inlet. You should NOT be able to blow thru the pump by blowing into outlet.
If the pump does not pass this test, disassemble pump and check the parts that must be in an exact position or must be in an exact relationship to other parts.
After pump is installed, squeeze primer bulb until firm. Check pump and connections for leaks. Correct any leaks before operating motor.
