FORCE 125
eddsull3
OVERHEAT ALARM COMES ON AFTER
OVERHEAT ALARM COMES ON AFTER ONE MINUTE OF RUNNING NO WATER COMING OUT OF EXHAUST HAS NEW WATER PUMP KIT WATER TUBE IS CLEAR
"Thermostat stuck closed?????
"Thermostat stuck closed????? Try taking the thermostat out. Run it for a minute and if you get water out the exhaust and pee holes, then you've found the problem.
If that fixes the problem, be sure to install a good thermostat. Not only do you not want to overheat the engine, you also don't want to run it too cold."
