I have a 2013 F90 that has 90 hours on it and it will not make more than 3800 rpms while in gear, loaded. When I run in neutral it will make 5400 easily. I have replaced all the plugs, the fuel line, cleaned injectors, checked the anti syphon valve. Today while underway I unscrewed the fuel cap thinking there may be a vapor lock, it did not help. Plus I checked the bulb and it was not firm. I am wondering if the high pressure fuel pump is malfunctioning or if y’all can think of something else to check? Also, a little history, I just bought the boat, when I tested it it ran fine. We did the compression and leak down check and they were great. Plus, there no faults stored.
Any help would be greatly appreciated!
Thank you!!!
Thank you!!!
