Exhaust & baffle gaskets , torque specs for bolts!.
garoylh
1991 Mercury 40 Classic, two stroke!. Need torque specs for bolts to end caps & exhaust baffle gaskets!. Replacing both gaskets, but don't know what the bolts torque to! Please Help & respond!. Thank You!.
Thank you! ,very much for a reply !. To make sure, let me give more of a description!. At rear of engine facing spark plugs, on left side of motor is a plate with bolts around it!. i took plate loose, there was a gasket and then exhaust baffle plate and another gasket to aluminum block!. is this the same you listed in reply post?. Thank You!.
