tinkerwalsh
hey everyone - first post here. stoked this place exists.
I recently got a whole boat set-up. a simple fiberglass speed boat from the early 70s, with trailer and a 73 evinrude triumph. From the original owner and it is/was well maintained. i got it for next to nothing because the low end was toast. i found a low end - installed it. didnt go. realized there was a bad solenoid. replaced it - fired right up!
pretty happy about it. this is my first boat and first time working on a outboard. so this leads me to a few questions....
1) This engine is heavy. i tired to tilt it from the back of the boat (in my yard) and couldnt lift it. I was able to get it to tilt from the ground by pulling up on the low end. took a lot of strength. This is not practical in the water so am I missing something? should i be able to manually able to lift a 65hp engine myself?
2) This engine doesn't have a 'tell-tale' hole? perhaps it has a overheating horn? is there a way to test this? I dont want to blow this engine up.
3) The engine has never seen the salt water - but i am planning on taking it around some of the lahave island because there is really nice boating there. what should i used to lube the engine with? I seen people just spray them down with rustcheck?
Like i said this is my first shot with a boat and outboard motor. Its new to me - so is there anything else I should be aware of? any other necessary maintenance I should consider before i take it in the water?
thanks so much for the help!
