Would a bad regulator cause a Power Pak to drop a pair of cylinders? 1990 GT200 Evinrude
This is the demon possessed motor that had the backfiring out #4 carb and a dozen other issues, all that fixed, got it running this time and lost cylinders #1 and #2. Last time on the water I felt it lose power at WOT so I headed straight for the trailer fearing the worst. Checked it out in the shop and found the two cylinders 1 & 2 were not contributing to the idle effort, actually they were hurting the idle. I pulled the Power Pak and found the regulator had obviously burned up, black center, black streaks running through it. I had patched this regulator up once when I found the connectors had melted through at the junction block because they were loose. I checked it with a carbon load on the battery and it was still working, so I think it just now must have finally went when we were on the water at WOT. -My question is --- Would this cause Cylinders 1 and 2 - the Orange and Blue Primary pairs in the Power Pak to quit - did it damage the Power pak? It was a brand new Power Pak... Any thoughts? Would a bad regulator cause a Power Pak to drop a pair of cylinders?
Thanks everybody!
ronchast
Thanks everybody!
ronchast
