Hey all, I'm not new to wrenching but this is my first boat. I have only owned it for a few month but I cant get it started. I'm going to write down everything I know about it to hopefully help answer many questions.
-When I got it, the cylinder head and cover were cleaned and had new gaskets so I assume someone was in there recently.
-I tested compression and have 105 on the lower cyl and 110 on the upper.
- points, condensers, and coils are all new and set correctly. .020 for the points as the manual and flywheel both say, and coils are positioned correctly.
-spark verified by a spark tester on both cyl. Looks like it may be weak? But sparks reliably.
- new plugs. M42K part number.
- starter rebuilt, it spins very fast, can't get rpm reading while cranking from the front.
- I rebuilt the carb with both the parts manual and the service manual right in front of me. I'm fairly confident I did it correctly, but it's the first time I've done this specific carb.
-It has ran for about 10 minutes total since being back together. It never ran well.
- when I pulled the plugs out for compression test, they were soaking wet. I was able to fling moisture off on to the shop floor. I'm assuming fuel/oil but it wouldn't light on fire with a lighter held to it.
- the 5 gal gas tank was about half full when I got it. I put 1.25 gallons of fresh 40:1 in it before messing with it.
I'm going to mix a fresh batch of fuel and try to run it off of that with new spark plugs. I'll report back what I find.
Any other suggestions are more than welcome.
