Hi all new to this forum I have a 84 Evinrude 20 hp picked it up a few weeks ago for 300 bucks. I had to put a rewind rope on it gave it some new gear oil and a fresh set of plugs threw it in the test tank and to my surprise it started !!!!! The motor ran ok but not great and seems to have a lean cough ?? when you give it a little bit of choke it smooths out and runs ok....... With out the choke out a bit cough, choke, sputters and when it coughs hard enough it will quit so rebuilt the carb drilled out the welch plugs, disassembled the rest and submerged it in carb cleaner re assembled after a couple days soak and still same problem!! I have adjusted the jet in and out till I found the sweet spot but still not much improvement on the low rpm idling and from just off idea rpm to wot is all good revs out nice and sounds pretty good.
Im stuck thinking its electrical possibly but also believing it not electrical because of the fact that the choke helps smooth it out.
throw me some ideas tell me what you think
thanks for any of your help
