Evenrude parts for long to short change
singbeda
"i have a 1978 25 horse evenru
"i have a 1978 25 horse evenrude mod.# 25853c and would like to know what parts i"ll need to make it a short shaft. it has the removable mid section, it doesn't look to hard but any info or how to posts would really be appreciated"
"I'm just going to use com
"I'm just going to use common sense here and guess, short drive shaft and short shift rod. Everything else should be the same."
"The water tube possibly but n
"The water tube possibly but not the drive shaft, the shift linkage could be cut and welded back to new length."
"Depending on whether or not y
"Depending on whether or not you could find a decent used driveshaft, a jack plate or transom elevator might be a considerably cheaper option - heck, if the boat isn't too fancy a piece of 2x6 could be used to fashion a mount to get the motor up the 5" you are looking to lose..."
