settimo velo
I bought myself an alignment tool on eBay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370503133199&ssPageName=STRK:MEWNX:IT which I've been using to fit twin V6s in my Settimo Velo. This is not an OEM tool but I hope it is fit for purpose as they have good feedback ...
I've fitted and had a go at aligning one engine and have just put the second engine in today. A couple of things are bothering me:
1. I cannot achieve a level of alignment so that the tool slides in freely with 2 fingers i.e. as per the Mercruiser Installation Manual. I can only achieve a firm sliding fit, which seems to be due to the weight of the tool and the close fit of the tool in the gimbal bearing.
2. The alignment instructions from the manufacturer of the tool call for the engine to be rotated through 90 degree increments to recheck alignment once initial alignment has been achieved. However, the Mercruiser Installation Manual does not call for this.
Also, I believe that the hull must have flexed a little when I put the second engine in as the alignment tightened up and will need to be adjusted, again. It occurs to me that things could shift again when the boat is lifted and, as it is wood, I guess there will be some take up and movement when it is in the water.
I do not yet have any drive units, so I am unable to compare tolerances with the alignment tool, to get a better idea of the quality of alignment I need to be looking for.
I'm not sure where this leaves me so would welcome any shared experiences and advice ...
