DT75 1995 crankshaft lower oil seal(s)
driver2008
[h=2]DT75, 1995, crankshaft lower oil seal, how to remove and replace?[/h][COLOR=#6A6A6A !important]03-13-2019, 10:13 AM
[/COLOR]
Item 26 was damaged when drive shaft was removed. Can item 26 be removed/replaced from outside the crankcase by simply hooking it out from item 27, like a drive shaft seal on a car, or does item 27 have to be removed, which might mean splitting the crankcase. Also, I'm puzzled as to why there are 2 of item 26, and a further oil seal higher up, item 25.
