" I have a 1988 or 89 Mercury
" I have a 1988 or 89 Mercury engine. It will either run at 3000 rpm or wide open. I believe I have narrowed the problem down to the stator. The manual states that the ignition system on mercury engines is either a thunderbolt phasemaker or a thunderbolt breakerless ignition system. According to the manual, My 1988 or 89 35hp engine uses a breakerless ignition system.It states that this system uses a stator with two coils. It does nor refer to the coils as high and low speed, but the manual does refer to the stator coils on the phasemaker system as high and low speed. I believe the stator coils for my system are also high and low speed, but this is not indicated in the manual. I feel like the engine may have a problem with the high speed stator coil if it is in fact a high and low speed stator coil.Does anyone feel like I am on the right track? As I stated earlier, the engine will usually start with the help of the fast idle lever. But, it will only run at about 3000rpm regardless of where the throttle is positioned. Sometimes, I will be running along and all of a sudden it will kick in and run wide open. The response is instantaneous and there is no delay. Also, I may be running full throttle at 5400rpm and all of a sudden I slow down to 3000rpm. It's always one or the other.The slow down is immediate as well and this is what makes me suspect an electrical issue. "
