I ran out of time to fix this, and haven't had the boat out because the weather in NJ has sucked for almost 6 weeks. Rain, floods, trees down, hurricane Irene, and even a minor earthquake. In any respect, I have a lot of maintenance to do on the Formula, and still have it at home. Anyone ever deal with the mercathode electrode wire passage, it's located on the bottom of the B1 and the passage goes through the transom?
I still have a leak at the bottom of the transom. Not much of a leak, but it needs to be fixed. Looks like it's coming in from the mercathode electrode wire passage. ON the INSIDE of the boat, the water is coming in from the lower passage shared by the hydraulic lines and wires for the electrode. OK easy enough, just pull the two electrode bolts, provide some slack to the wires (orange and brown), and it will drop down, and I can inspect the situation. NOPE. I can pull the 2 screws BUT plastic housing for the electrode loosens, will not drop and is steadfast. Used a little force, but afraid I will crack the plastic housing. There was a mercruiser service bulletin out (88-6) http://www.boatfix.com/merc/bullet/88/88_06.PDF this says to fill the voided space with an approved sealant. Is it possible that the previous owner had serviced this and now the sealant is ROCK HARD, therefore giving no play in the wires so I can take a look without demolishing and buying new parts? How would the experts approach this?
