I have a Chriscraft constellation 500 with twin Detroit 6V92 motors. Over the past few days I have discovered bubbles in my water heat transfer box. They are small frothy bubbles rather than big bubbles and are slowly pushing the fluid out.
I have dissolved and put seven seal lock tablets into the system. Thy are supposed to seal any leaks in the head or motor. I have then run the motor for 30 mins at 1000revs for 30 minutes, left it to cool totally. I have done this now three times but there does not appear to be any appreciable difference.
I have fitted a new recovery tank system with a further overflow tank complete with new recovery 7lb radiator cap. I burp the motor and fill the heat exchange to the top before starting. When running at 1000 revs for 30 minutes I am getting about 5 litres of fluid in the overflow tank.
The engine starts first push and does not miss, there is no apparent smoke from the exhaust on start up and the motor runs perfectly. I have used a thermo gun on both motors and there is no appreciable difference in heat between.
There was a suggestion that it could be the water pump impellor cavitating and pushing bubbles into the water. could this be the case? would the water pump cause bubbling in a fluid filled system and would this be enough to push the fluid out?
I live in a country town in Australia and not trust the local diesel mechanics in this town(I was quoted $40000 to repair the other motor when it blew a water hose which I fixed with a $5 hose - not a complete rebuild)
Can anyone offer any advice please
