Can anyone help me with this question?
I see that the manual recommends taking the flywheel off to set initial timing on crankshaft. Can I simply use the Index mark on the plastic cover; line it up with the 10 degree below top dead center index mark in the flywheel? Surely if I mark the block at this point then if correctly aligned with the cam shaft set up per manual this will be close enough to get engine started?
