I finally got to take my boat out after rebuilding the starboard honda 2003 200 cylinder heads after timing belt pulley flew off..Good news is that the outboard ran flawless...bad news is the port side outboard crapped out on me 5 hrs into my trip and 32 miles out. I was idling and it just turned off...when I turned key switch I had no lights on panel..It had been running perfect with no warning lights on..I checked battery connector terminals, took them off and scraped them and reconnected...they seemed fine..I checked all fuses on port side of engine including the main one that is in its own housing near starter. I tried to jump starter with screw driver and could hear starter spin, but not engage..I also swapped out harnesses at the ignition key thinking it might be a bad key switch, I'm not the best at troubleshooting electrical issues, so I certainly appreciate any help.
