" JoeReeves,
In reading the
" JoeReeves,
In reading the post about Surging Evinrude, you mention cutting in and out which seems to describe the situation with my 89 175 Evin. I ran the continuity tests on the wires. I would actually get a reading but it seemed difficult to get a good contact within the boot with the probes of the ohm meter. In any case I am replacing the whole wire set. Question is should it be that difficult or is this what you mean by intermittant. I actually reset the spring on all the wires and engine ran good for a while but then she began cutting-in-out.
Also when checkin the actual coil what do you mean by "using the ohm meter on the prong you'll see within the coil". Is that from prong to ground? I've ordered a wire set from Boatus (MagStar) by the way, not from the dealer.
Thanks for your input
Gus "
In reading the
" JoeReeves,
Gus "
