myunclepapa
I have a 1989 50 horse power Johnson that sounds like it need some oil in the power trim it is slow about coming up it seems to run a little while like it is trying to pick up oil and then it will work fine I just had new seals put in and it started this after I had it worked on it was leaking around the push/pull shaft, called the man and he said to run it up and down a few times and get the air out but this has not helped, the only place I can see to put oil in is on the side and you have to pull the bottom shaft out to get to the plug, is this right or am I looking at it wrong. J50TlCEC G 02326785---------Thanks OTTIS (Have not used it in a while since having it repaired and the man says it is to long a time for him to recheck it with a service charge)
