I'd steer clear of the Ocean series also.... unfortunately!
I believe that you are committed to changing the transom shield in order to get away from this series drive. You'd have to speak with someone more knowledgeable than myself to answer this!
IMO..... and IMOO, one of the best, tried and proven Volvo Duo Prop drives is in the AQ series. For me, this would be the DP C drive.... or DP C1 or so.
I think that Volvo shot themselves in the foot when they discontinued the AQ series drives, and went with the SX and DP S in the early 90's.
They did this to capture a market and be more competitive with Mercruiser, who has been owned by the Brunswick Corp for years now.
The Bayliner market disappeared for Volvo anyway because of this.
So now their drive uses the same transom cut-out as does M/C, but this caused the system to go from a Main Suspension fork type geometry, to Gimbal system geometry! They both work, but the simplicity of the earlier system was excellent... and superior IMO!
No Gimbal type suspension system. No Gimbal ring. No Gimbal Bell. No Gimbal bearing. No rubber hub drive coupler. No annual engine coupler alignment. No thru prop exhaust just to name a few!
AQ offers; All steel drive coupler, PDS and bearing (no Gimbal bearing), NO annual engine/coupler alignment, Main Suspension fork geometry, easy transmission and bellows service, independent exhaust outlet, no shift cable bellows, and so on!
Now, some may think this is Old School thinking! Or a result of my older age! However, I'm not alone. I've spoken to many of my Volvo tech friends who feel the same way as I do!
If this were my boat, and if really considering a better system, I'd go for the AQ series, despite what some may say.
It would be out of congruency for the year model..... but anyone who knows the AQ series may find this a real plus! I sure would!
