I have twin Chrysler 440s in my boat with Carter AFBs. I wanted to run my carb problem by an expert before I tear into my problem carb. One of my carbs was rebuilt this past spring. Since that time, whenever I shut down the engines, the rebuilt carb seems to absorb the heat from the engine and gas seeps out the bellhorn gasket and through the manifold/carb gasket, at the rear of the carb. The other engine has no problems. Both carbs run efficient when operating. It's at shutdown when the problems occur.
1) Is there a gasket for the base plate that may deflect the heat better?
2) How do I keep the carb from getting so hot after shut down that it boils the fuel, thus seeking its way out the gaskets?
3) Should the gaskets (bellhorn, base plate) have a sealant?
4) I have also seen gas trying to seep out the fuel inlet fitting.
I think the carb is so hot it's forcing the gas out the weakest points.
Any help would be appreciated!
