A few weeks ago both motors quit while out for a cruise. First the starboard and then the port. In both cases I found that the carb bowls were dry, as there were no squirts from the accelerator pump when the throttle was pumped. I got the motors started by removing the spin-on filters/separators and splashing some gas down the carb throat. While removing the spin-ons I heard a "pssst" vacuum relief sound. I replaced the spin-ons with my on-board spares and limped her in at around 1,500 rpm because the motors would quit if I tried running harder than that.
Back at the dock I found that the rubber portion of the my pick-up tubes had completely collapsed internally. I have a single 220 gallon tank with a pick-up tube for each motor. I replaced the rubber, and was sure that I had found and corrected the issue.
This past weekend my starboard motor quit again after about 30 minutes at crusing speed (2,000-2,500 rpm). Again, I found that the carb bowl was dry, as there were no squirts from the accelerator pump when the throttle was pumped. Again I removed the spin-on fuel filter/water separator in order to pour some gas down the carb and heard a "pssst" vacuum relief sound when removing the spin-on.
I poured a splash of gas down the carb, replaced the spin-on with a brand new unit and the engine fired up. I limped it in at around 1,500 rpm in fear that the motor would quit again under a greater load.
My port seems to be fine after the pick-up tube replacement, but something is still causing me to loose prime on my starboard motor.
My tank vent is clear, and I'm going to check all lines and fittings on the starboard side. I have no anti-siphon valves, only manual stop-cock type valves. I don't think I'm sucking air, since I can hear that vacuum relief sound when removing the spin-on.
Could a fuel pump be the issue here? Anyone ever see a fuel pump work at low speed, but fail at higher speed?
Thanks,
JJ
Thanks,
JJ
