HI, need some advice and what I am pretty sure is a carb problem..But I have been wrong before. My 170 starts ok...After running for a while, it starts to run rough, sputter then stalls. Then its hard starting,...If I pump the throttle and put in full position it will start. I bring throttle back to faster than idle position and it will start to stall..I can pump it but it bogs and stalls. It actually ran at fast idle for 20 mins this way after a 2 week sit. I broke down this way in the middle of Cape Cod bay a few weeks ago...All the cranking actually killed the started. When I got back I took out the little filter in the carb and it was all black..Figured this was the problem. I just replaced the starter cleaned out the filter but it still does this stalling thing after running. I pumped the fuel out of the bottom of the tank and its clean and water free. I use treatment religiously when I fuel up.
DO I need to rebuild the carb? Any ideas? Fuel pump, accelerator pump? I am disppointed as I had wanted to get her out this weekend..Supposed to be near 80....
