"That is strange. I would susp
"That is strange. I would suspect this boat has either been in salt water at one time or the other and not properly cleaned, OR there was a manufacturers flaw in the initial powder coating process. The typical cure for excessive calcium build up is either straight vinegar or for a stronger brew - a 10% solution of muriatic acid with water. After the muriatic acid has desolved the calcium, thoroughly wash it off of the surface because it will also attack any bare metal. After cleaning off the calcium, closly inspect all the surface and use very fine steel wool to smooth out any lumps or cracks.
At this point, then you should consider re-coating the outdrive. If it is in good shape, consider some sort of polymer clear coating specific for marine environments. Alternatively, consider repainting with anti-fouling metal paint. There are folks on this forum who can give you some good advice on marine metal coatings. I'm not one of them."
