Siwash Rock
Ok I'm new so excuse me if this is dumb, but one of the two bolts attaching the sea water pump bracket simply will not come off (Merc 5.7L 350 CID 1995 v-belts). The nut rotates both ways but the threaded bolt prong part stays in place. There is no backing nut to the threaded prong - it looks like it is screwed into the engine block. Does this mean the thread of the bolt and engine block are toast? Or is there some tool or technique I can use to free it? The prior owner used two nuts on the prong/bolt thread - one came off easily. The other nut is stuck. The lower bolt came out easily.
Also, would you big dogs in the forum replace old nuts/bolts/washers with new stainless steel to re-attach the bracket to the block?
