I have a 91/4 X 9 4 blade on my 2014 BF-9.9D pushing a 12’ aluminum boat. I have the same problem as you, too fast for trolling when the fish aren’t actively biting. I turned down my idle a bit and that helped somewhat so I turned the idle down a bit more figuring I’d be golden. Not so, if the idle is too low I ended up with a hard starting issue. Did this last year when the engine was just out of the break in period, over the fishing season last summer I did notice that the idle revs appear to have increased a bit. I’m hoping this year I can get the idle turned down 1/8 to 1/4 of a turn without causing me the hard starting condition. Adding more weight to the boat helped a bit with slowing the boat down, I used my dog (65lbs.) and a 1/2 full sandbag (20lbs)Well maybe the prop I have is not standard issue I did buy this motor used ut has the 4 blade 10x6.5. I wonder if the 91/4 x 6 1/2 might be the key ? I went through the same BS with the big motor when new. Thanks for the info it is much appreciated
