Hello, please tell me, were you able to find the reason for water getting into the oil? I have the same motor and the same problem. I can't find the reason. Thank you
Hi. still waiting for parts. Ian replied saying Honda fix is new oil pan gasket & extra torque on bolts.
I 'm of the opinion the water is being sucked into the oil pump through the oil seal. My reason for this theory is
the BF50 s don't seem to have this problem & they have more area between the oil pan & water compartment.
The main difference is the oil pump is on the crankshaft & not the camshaft, so to me that points to where the problem
is occurring .I feel the water is being forced into the driveshaft section through the gearshaft hole in the leg
& forced past the water seals on the driveshaft , due to suction created by the oil pump at high speeds.
Honda manual states the water seals to face back to back.(I will be facing both lips down to try to stop water entering.
The reason I'm sceptical of the gasket causing the problem is 5 local pro fisherman purchased Bf60 s around 2000
& all have failed with water in oil ,& have been repaired by Honda dealers with Honda's Fix & at least 3 of them
have failed again. one of them has failed for the third time. The owner of that one has thrown it in the shed
& put his old BF50 back on to keep working.
