I recently replaced the water pump and overhauled the carbs. Let the engine idle for nearly 2 hours through the wash port hose connection with no overheating. Took the boat out on the water and it ran good for about 45 minutes at full speed, then overheated and shutoff. Had to get a tow back. When I got home I took out the t-stat and it appeared to be fine. The proceeded to look at the water pump and I noticed the wash port screw was gone. Must have been lose and fell out. Also the water pump looked fine.
Could the wash port screw missing cause the engine to overheat?
If not I need some ideas on what could cause the overheating.
